moparmat2000
Looking for a small block 6 bolt neutral balance flywheel thats so worn and heat cracked it cannot be resurfaced, and a small block bellhousing in either aluminum or cast that's cracked or damaged where it cannot be used on a vehicle. Basically junk pieces. I am wanting to put together an engine run/break in stand, and only need these pieces to be able to start an engine.
