j par
Well-hung Member
Yep that's what I said..
caltrac rear Qa1 frontSS springs? Caltracs? Four-link? Adjustable shocks? Ladder bars?..
So what's your seat dyno say???caltrac rear Qa1 front
track yes been doing that since 1986I wasn't questioning whether you could drive or not. You've posted five times in the last 17 years so I wouldn't have a clue if you just bought the car yesterday or you've been drag racing all your life. With that said have you been drag racing the demon at a track?..
my but dyno will lie sometime .. lolSo what's your seat dyno say???
Certainly an experienced driver like yourself, and that has driven the car, will have more insight than us which haven't even seen the car LOLmy but dyno will lie sometime .. lol
I have an ideal of what I think it should run . just looking for opinons.Certainly an experienced driver like yourself, and that has driven the car, will have more insight than us which haven't even seen the car LOL
10.80- 10.90 I hopeIf chassis in tune are dialed in then 10.9ish
Easier when abcessedPullin teeth would be easier. With tweezers.
Oh I see so you know what you're doing...10.80- 10.90 I hope
I hoping for a 10 second street car. The whole ideal of this car is to build a car I couldn't afford when I was a kid.Oh I see so you know what you're doing...
Such a completely different story..
Like I was saying 10-7 to 11-7 would have been my guess depending on many things. So now knowing some of the story instead of trying to do this by Crystal Ball I'm back down into the 10-7 area... Again though most of what seems to be looking at setting you back is the weight issue...
Before pictures I got bored ... redid the whole car at home while off work dodging the Rona. Lol
Hi, I would like to know what you guys think my car will run and how much horsepower. 74 Duster, full interior, mini tub 28/12 rear tires. 391 gear, 727 trans with a 3500-4000 PTC converter, 71 360 .060 over 414 cid. trick flow 190 heads, 12.2 compression, 590/587 248/250 hydro roller cam , 850 carb on air gap intake, 1 7/8 TTI headers. what do you guys think ?
By the looks of all those pictures you’ve done a ton of work over those 17 years on the car vs. spending your time here posting, so you get a pass in my book! The “anti-bench racer” if you will!! When’s the soonest you’ll be able to run at a track?Made a few post tonite..lol more than I did the lasts 17 years . Lol
march for a 1/4 mile run.By the looks of all those pictures you’ve done a ton of work over those 17 years on the car vs. spending your time here posting, so you get a pass in my book! The “anti-bench racer” if you will!! When’s the soonest you’ll be able to run at a track?
