geminimotors
65 Barracuda, slant six, 833 4 speed. My shifter isnt centered and just barely contacts the forward edge of the hole in the floor hump in 1st gear. Its too far forward to install the boot without badly pinching it. I have the correct shifter(forget the #) and mounting plate # 2298, which I think is correct and shift rods from Brewers. Motor and trans mount line up nicely with K frame and cross member. Shift rods are good, except reverse is at the end of its adjustment.
Does anyone have any ideas about this, or another mounting plate?
