Stop in for a cup of coffee
Service back up....woo Hoo....
Chris didnt I send you a set of older points for that? If they wore you might have a bent shaft easy check, Gap, turn the engine, check the gap on each lobe if it is to tight or loose guess what?
Not for the 60. You sent me some for the polara
Morning everyone. Nice day in the patch, low 50s. Back to work now, more wells to check.
Cheap plastic. Probably recycled milk cartons. LOL You need to convert that 60 to Pertronix.
Not my call on that one. Grandfather wants it as original as absolutely possible. The tires we bought and put on it in are even remakes of the old bias plys. That was a pita to find.
Welding on the dart all morning and my back is killing me now. Note to self, chemical dip the car next time, would have been so much nicer. :BangHead:
