Stock block , heads, crank,pistons, rods
Good valve springs
Cam 498/274. 512/286
Supposed to pull to 6500
Good valve springs
Do you rev it that high? That is a roller cam right?My magnum 318 stock goes to 6000 easy I’d say 6500 lol
Yeah I do, it has a 600 cfm carb rpm air gap intake that’s about all I added to the motor. And yes roller camshaft, all magnums have roller camshaft although the 318 magnum has a more nicer camshaft specs than the 360 magnum why I dunno.Do you rev it that high? That is a roller cam right?
Thanks I definitely have Hughes good springs as I heard stock magnums were done at 5000With the right sprAngs, it'll go 6500.
Yep shift at 6000 rpm, 500 above peak HP.This is a 380hp create engine
750 cfm M1 single plane and similar cam
Should be similar output not down too much at 6000rpm but probably fall quick after.
Good valve springs
Yes the 1110sThe 1110?
Yes the 1110s
Hughes told me that they good to 6000 plus and I believe.550 lift does that sound correct??
I thought about it and I remember spending over 200 so I must have gotten the springs/retainers/ locks package and I think I also got some good valve sealsYup. That's a decent sprAng.
