I'm just curious, would it be possible to set up your six pack set up that are original vacuum operated secondaries with the mechanical linkages instead ?
Can you just remove the vacuum pods and swap the stock linkages for the mechanical ones ? Would you need to do anything else in particular or would it be able to run just like that ?
I know that if anyone can answer these questions they are on this site.
Therefore a thank you is in order in advance.
Regards,
MAPS
Regards,
MAPS
