Uremco’s Holley 1920. Just don’t do it.
There is a simple fix for that called a pressure test. When you go to buy a rebuilt, you take your pressure tester along and test the carb before you buy it; just invert the thing and pressurize to 5psi.It should hold that for a minimum of 20 seconds.
If it doesn't, move to the next one.
