[Found!] 1 standard/original 360 LA piston
ragtopfury
Manchester, MD
So we managed to break the skirt on one while disassembling the 84 360. Anybody have a single standard bore LA 360 piston for cheap?
Don't need the rod. Just the piston and wrist pin.
I just about **** when i saw this ad....i just did the same exact thing...mine is also an 84 360. I ordered a new one from Orielly's for like 30 bucks. Its made by Mahle...if this helps..
I figured I could probably get one fairly cheap at a local parts store, but thought I'd give FABO a chance to get rid of a piece of something they don't need and feel useful as well. I'll give it a couple of weeks.
I shouldn't be, if I am its news to me. I am in southeast PA. I am planning to go to the Maple Grove Swap Meet Sat.
Sterling is setting me up with a single.
In the meantime still going after the set of original flat tops as well. I've got 2 bare blocks in the shed. They won't go to waste.
Thanks!
