Need some longer studs, need help choosing Size.
C2ndLTpigeon
Mopar or no Car!
Indio California
I just got some new tires installed on my 73 Valiant, my main concern is the rear tire distance from the leaf springs. I would like to have 1 inch and I am currently at 1/2 in from the leafs.
I am thinking about a 1/2 in spacer and will need to change the stock studs for some longer ones.
What is the stock length of rear wheel studs on a 73 Valiant? Would all I have to do is look for some that are 1/2 longer?
Thanks.
Picks of my wheels and rear spacing
A 1/2 " is fine I have ran them almost touching with no problem.
You are good to go if you ask me.
True that, I was just trying to go off what most people recommend about an inch spacing but ill see what it does after a week.
Unless you are going to be canyon carving or auto crossing, you 1/2" clearance will b e fine. I ran 295/50 x 15's on a B body with 1/4 to 3/16 clearance, tires never touched the springs.
Mine is less than a 1/2", go have fun with it.
