dartfreak75
Restore it, Dont part it!
For break-in don't worry about initial. Start it get it straight to 2200 and set your timing around 32 total. I ended up around 33 and my break In went well.
You are absolutely correct but this info is for guys that are having trouble on the first fire up.For break-in don't worry about initial. Start it get it straight to 2200 and set your timing around 32 total. I ended up around 33 and my break In went well.
Good jobWould like you to check my work.
Thank you. And it’s “ok” or normal that my mark/ rotor position is a little past the #1 cap terminal?Good job
only the vac advance changes the rotor phasing (not initial or mechanical). it shifts it CCW (on a SB) so even though I would like the rotor (pink mark) to be a bit closer to the #1 cap terminal then where it is but I think you will be OK. EDIT I say that the rotor terminal closer to the trailing edge of the cap terminal is far better than it at the leading edge as vac adv will shift phasing back CCW from the trailing edge closer to the leading edge so you are getting as much face to face close contact in that span as possible.And it’s “ok” or normal that my mark/ rotor position is a little past the #1 cap terminal?
FINALLY got my 360 a hair's breath away from starting it. I have 2 questions, though.
1) The car still has 87 octane gas in it from last year. The gas still smells ok but my comp ratio went from 7.8:1 to 9.2:1. Previous cranking pressure was 135 and new is 150. Will it run ok on the lower octane gas for start up and initial break in or should I figure out a way to get it out of the tank and put premium in it? I intend to drive it with premium.
2) Where to set the initial static timing? I was thinking 18*. What info do you need to posit a guess?
