Princess Valiant
A.K.A. Rainy Day Auto
So would it be as easy as buying a napa drain plug, drilling a hole and welding a standard nut on the inside?
Will the drain plug seal in a regular nut?
Where is the best place to put a plug..... side or bottom ?? I was thinking on the rear vertical part of the pan.
