Dave Lucas
63 valiant signet convertable 200
I have a 1963 Valiant with a /6. I'm looking for a rebuild kit for the fuel pump because I want to keep it original. Where can I get one?
If its a crimped style, they are not serviceable. If its a bolt up turret style you can remove the check valves and spring and maybe use an edelbrock diaphragm.
Please send info of where to order this kit and the cost with s&h.Easy. Then and Now kit CK-123 for the Carter M2996S. It will put out 9lbs. If your carb is sensitive to that I have springs that will set it to 4.5lbs View attachment 1715714613View attachment 1715714614
Sorry, I had to make it large on my phone to see it. Thanks.The web site is right there on the bag in the picture, along with the part number.
