Will i need to shorten the drive shaft or will it bolt up to the yokes i have in my 7.25?If it comes out of a 73 or newer A body yes it will bolt in. You will need The proper U-bolts and shock plates.
PM'dPM me, I Have a couple.
What would be the proper ubolts and plates... how will IIf it comes out of a 73 or newer A body yes it will bolt in. You will need The proper U-bolts and shock plates.
ugh thot soYou will have to shorten your driveshaft.
