[WANTED] 318, 340 or 360 motor mounts
plumkrazee70
Medford, Oregon
I am in desperate need of a set of motor mounts for a 67-72 V8 K Frame. I just got my car on the road and there is a terrible vibration. Turns out I have the wrong motor mounts and the motor isn't sitting level.
I have read so many threads about the difference between 340/360 mounts vs 273/318. All of it makes sense, but I am having a hard time distinguishing them by pictures. I am already $85 on the set that I got and they aren't right.
Thanks again.
I see you have a 67-72 V8 K frame ?
What engine is going in ?
67-72 V8 Kframe with a 340.
I'll take whatever is out there at a reasonable price. If they are 340/360, great.
If they are 273/318 that works too.
273/318 mounts won't work unmodified on your 340 - GTX John is cutting you a deal on hard to find mounts, buy 'em
I don't see how being unlevel would make it vibrate. They do have different thickness of the rubber motor mounts to level up your engine .
Sounds more like you may have the wrong torque converter in there. Or the engine itself is out of balance.
My thought was, I need to get the engine level before I can take accurate measurements of the tailshaft angle in relation to the pinion. I don't think it's the engine, since I've had it running and driving, albeit, with the old 904 and worn out everything else. Lol. I have a "built" converter on the way, I was going to do that anyway, just not as soon, but I figure might as well.
