[WANTED] 340 kickdown linkage 1971-2
LS&S
Aylett, VA
Rating - 0%
0   0   0
Have 1971 3512100 intake, factory cast iron 340 high rise. (Not for sale)
Want to buy matching kickdown linkage that will work if I install Carter thermoquad.
Intended use: convert 1973 360 from 2bbl Holley 2210 (bog city) to 4bbl.
Please post pics and price.
Thanks, Ben
It's tough to find that upper rod. Lots around for the AVS but not so many for the TQ (or so I've found). It needs to have an adjustable slotted head and a wider offset because of the TQ's width. I bought a few before I found the right one.
Thanks, Ben
You Need complete *** or just upper half ?
The current linkage is for 1973 Holley 2210 2 barrel. I was thinking I need the whole assembly. Don't have to use Thermoquad, if there are better spread bore options with an electric choke. Was looking at Holley Demon 1900/1901 and wondering if I can mount it with just a gasket and if their linkage adapter will work with Chrysler linkage. What do you have?
Examples:
Edelbrock Carb
1481 Edelbrock linkage bracket
