aaronk785
I se where some builders use 1.6 rockers on the intake and 1.5 on the exhaust. What is the purpose of this?
What cid did you see this on and what heads?I se where some builders use 1.6 rockers on the intake and 1.5 on the exhaust. What is the purpose of this?
Likewise, such as a small block chevy.I have seen it on a variety of brands & engine sizes.
So I guess I should do 1.6/1.5 if I order the wrong cam for my engine build?
It would always be an interesting dyno test....So I guess I should do 1.6/1.5 if I order the wrong cam for my engine build?
