My buddy has a 72 Dart that was previously wrecked, and needed a k frame. He went to the junkyard and got all the parts, including a spool mount k frame, years ago to repair. Did all the work himself, and drove it a bunch of years. I worked on it at one point and noticed the lever that the torsion bar adjuster sits it was rubbing the subframe. I assumed the spool mount k frame is slightly wider at the lower control mounts, causing this. Fast foward a bunch of years, different engine, and new QA1 control arms. Got the car back together and just had it aligned. The alignment shop could only get - 1 degree camber . Has anyone else ran into this ?
