What Are You Doing To/With Your Car Today?
Dissembling this 750 double pumper. I bought it cheap with it well cleaned and a new kit installed. It’s supposed to be ready to run but you know how that goes !
Got my firewall striped and epoxied. Got some pieces from AMD and rebuilt the cowl to inner fender pieces. Welded in the other piece that holds the fender on at the top as mine was rotted out. Sanded down the area behind the splash shield and epoxied it. Progress is slow but it’s gettin there.
Drug store run for pop, milk, bread and most importantly chocolate chip cookies.. lol Short cruise around town this round with us under full stay at home orders and still not sure on the OPP's stance on harassing us about where we're going..
Just tell them you need to exercise the Musclecar's legs. It is true, they get issues by sitting too long!
Total of 5 Carbs broke down and cleaned in the Ultra Sonic Cleaner today, dry and ready for assembly tomorrow.
The last one was the "Old School"
Turns out you guys were spot on , flipped the center link around and put the tie rod towards the front of the car PLENTY of clearance now. Thanks!!! Proceeded to install QA1 shocks and the rotors ,calipers , brake hoses and lines from the Pirate Jacks kit. Everything went on smoothly.
Take Note: Those are the "New" 4" bolt pattern drilled and slotted rotors. Don't know if anyone else offers them ?
Swapping out engine and third member, going with green axle bearings. And exchanging the rear yoke for the smaller one with a new nut and seal. Should keep me busy for a week or two..maybe three... lol
Adjusted hand brake, swapped the old rusty headlights to these cheap ebay ones (I dig the look, let's see how they hold up) and had a small drive around the neighborhood. Next thing is to take it to the MOT.
Trans pan , filter and gasket then fluid, shifter linkage will take some time. My to do list today if it warms up out of the 33 degrees I woke up to this morning
Working through the carbs:
There is an antique early '67 AFB coming up for completion too. Came off of a 67 383 4 bbl 10:1 cr factory original engine.
