C2ndLTpigeon
Mopar or no Car!
So after spending some money trying to build a 318 and hearing the "you should just build a 360" opinion and I finally fell for it. I managed to pick up a 360 with 727 for a good deal to replace my 318-904 set up. This is a street car that needs some more power than the whiplash 318 im running.
I'm looking for a good build suggestion. It would be nice to have compression in the 9's I would like to keep costs down so I plan to use stock Iron heads with 1.88 1.60 valves with some port match and bowl clean up. Stock crank and rods are good for reuse.
Looking for piston options and cam options.
I have the following components that I plan to reuse with the 360: Headers, Protronix distributor, Performer air gap intake, edelbrock 600 (probably going to need bigger) and I cam running 3.55 gears in the rear.
Thanks!
Thanks!
