[Found!] 64 Valiant 200 Signet Trim
TheHomebrewed
Minneapolis
Howdy all. I'm looking for the trim piece for a 64 2 dr. Valiant 200 Signet. The trim piece is the one located in front of the passenger side rear wheel.
I also would be interested in the rear window trim.
Thanks in advance.
Thanks in advance.
I have the rear window trim and think I still have the 1/4 piece. Will look when I get home.
Thanks in advance.
Looked and don't have the 1/4 piece but I did find the rear window trim.
Have rear window trim as well.
What is the condition of the trim? A simple picture might be nice too. I've never installed window trim before, is anything else needed to install it or is it all set?
Thanks
I have V200 and Signet trim as well.
It looks like you have the passenger side trim that goes behind the door. I'd also be interested in seeing the window trim.
Thanks
I'm not sure if I'm using the correct terminology so I'll post a pic pointing out the pieces.
It looks like I may still have the corner pieces.
