74scamp360
Junior Member
Running brake lines in my 74 scamp which has manual front discs from a 78 volare swapped in. Can’t quite recall what the line size between the master and proportioning valve was supposed to be, the inverted flares in the proportioning valve look like they should be 1/4”? Any help would be much appreciated
