[SOLD] MOPAR BALLAST RESISTOR
jsjs1212
1969 DART SPECIALIST
Decatur IN
Rating - 97.9%
47   1   0
Hi - (1) good used working original Mopar ballast resistor. $6.00 + 1st class postage. I ship fast! Thank you.
Would you check if the ceramic shaft that the coil sits on is not cracked.
Easist way to know is wiggle one terminal and if the other wiggles the same it is not cracked.
If it is not cracked I'll take it.
