Thank you! I'd like to hook it to power but kind of unsure which wires. There's a red wire which I'm thinking is power and two orange wires that seem to connect to one which I'm thinking is the ground but I think there is a yellow and a black wire as well that could be ground. The others go to what looks like a gaggle of speaker wires and a plug. Where it gets kind of interesting is the antenna. It looks like two wires come out of the radio and into that resistor and then that goes into some kind of splitter as well.I would say $250 at least if working. Cool jewel!
Thank you for doing that research! I'll see if I can't put some juice to it and get it working.
Here ya go... Amazon.com : swr meterThank you! I'd like to hook it to power but kind of unsure which wires. There's a red wire which I'm thinking is power and two orange wires that seem to connect to one which I'm thinking is the ground but I think there is a yellow and a black wire as well that could be ground. The others go to what looks like a gaggle of speaker wires and a plug. Where it gets kind of interesting is the antenna. It looks like two wires come out of the radio and into that resistor and then that goes into some kind of splitter as well.
I do know about CB's is I'm pretty sure you don't want to key up the microphone without an antenna. And then also generally the antenna has to be kind of tuned to the CB?
I took that homemade cover off.
Agreed I covered that in post 3.JUST DON'T KEY UP THE MIC WITH NO ANTENNA INSTALLED..
It doesnt "has" to be tuned, but it helps . Just like all radio frequencies.Here ya go... Amazon.com : swr meter
I did hook up the red to 12 volt and grounded the body. The CB would turn on but I didn't get the radio lights so that must be the orange wire. I guess I just didn't get the lights to backlight the radio.Red is 12v power, orange is always lights, body is ground, but there is also sometimes a ground wire.
10-4I did hook up the red to 12 volt and grounded the body. The CB would turn on but I didn't get the radio lights so that must be the orange wire. I guess I just didn't get the lights to backlight the radio.
Of course I didn't even have the microphone connected or any speakers.
Manufacturing tolerance. 2 separate antennas has to be a better system.There will be two antenna connections, but perhaps only one antenna.
I worked on one of those a while back. I've got manuals with the wiring diagrams, but they're a little hard to get to at the moment.
Needless to say I am very interested in anything you can come up with. Thank you.There will be two antenna connections, but perhaps only one antenna.
That's "what's your 20" FYI.10-4 Rubber Ducky. WTF are ya!!??
