What Are You Doing To/With Your Car Today?
I adjusted my quarter windows today. Passenger side went well. Driver's side is giving me fits. So, I stopped for the night and will work on it again later.
Got the programmable shift light moved to where I can see it. It was on the steering column and would sometimes get blocked when steering the car with the left hand and right hand on the shifter. Now it shines right at my beak without issue. Was trying to keep it off the top of the dash and this spot works well.
FINALLY!! Set the motor and transmission back in the car!!! Tried to put the TTI headers in at the same time that didn't go well. Had to return the borrowed engine hoist so I gave up on the headers and just set the engine in place. This week I'll fight the headers in.
It lines up that way , if I moved it behind the ears there was a gap that would've taken shims or washers to fill. Anyone else have an idea???
Nice
But one suggestion...loose the Firestarter air cleaner
One good backfire and that thing will light up your car like the 4th of July
I didn't wanna disrespect his car. But that's the first thing that gave me the YIKES :(
Sure, and if it were a simple matter of "me no likey" Ida kept my mouth shut
But this is like seeing someone put a plastic fuel filter 2 inches from the exhaust
I'd rather point out the danger then shuttie and read how it burned down a week later
I call out the plastic fuel filter all the time. I agree to point out huge mistakes. Cars of this age are not replaceable.
Changed the location of the passenger side mount ( Thanks DODGY) and installed the drivers side header. Lots of clearance around the steering coupler now. Tonight it's the passenger side header and then touch up a few scratches from the install.
Old paint seems about an inch thick, but finding very little filler in the doors, even along the lines.
GetAttachmentThumbnail
I can't see the image. Interested on anything with paint as I am getting ready to paint my hood. this week
