Duster Antenna Delete Plug/Cap?
KOZ45
Indiana
Not planning on running an antenna. Have the bezel and everything removed.
Rather than spending $75 on a billet plug/cap what are other options?
Will Chrysler p/n 2860332 fit?
Hardware and home improvement stores sell these plugs which don't look too bad. I have seen them on cars before.
I ended up just buying a used antenna mount/bezel and used a small bolt in place of the antenna mast
Works for me
I put plastic filler in mine, I was just working on it AGAIN today. Having a bear of a time to get it flush with the fender
My 67 Dart 270 radio delete car doesn't even have a hole in the fender. Did they always come with holes?
No, radio delete fender plugs were '68-up. But I imagine if you found a factory delete plug no one would bat an eye.
