Mopar Ralley SBP value
RalleyRoy
Monroe, GA
Edit: 15 x 5.5 JJ 5 x 4 1/2.
What are they worth?
I have had these for years.
Came off a 78-80 ish Volare Road Runner.
Small Bolt Pattern. (Edit: nope)
4 rims, trim rings, centers.
Not perfect by any means.
Scrathes, dings, chips, one center missing the disc/?
Two more old scraggly ones from a utility trailor.
I would like to post them local and get them out of my garage.
I paid $200 for 4 wheels, rings, center caps and 2 new tires. They were BBP.
@RustyRatRod Those look pretty good but are LBP. $200 for the set easy probably more with those nice rings and 3 acorn covers.
I was trying to sell a fresh set of SBP Rallyes and new in the box trim rings at a swap meet, locally, and on here. Fresh Mopar brand Argent Silver paint.
The lowest I went was $300 and there were no takers. Originally I was hoping for $400 but quickly realized nobody wants 14” SBP wheels.
Im in the same boat. I just want to get them out of my parts shed. I’d let them go for just about any offer at this point.
You just have to find someone that needs them and are close by. Shipping is a killer on rims. Those should go for $200-$300 as they sit.
14 inch big bolt ralley are very common and don't go for much , unless they are 14 x 6.
Small bolt , harder to find , but you need to watch for stretched lug holes and mushroomed lug holes. Always look at the back side of a small bolt ralley , check the lug holes.
I have both , small and large 14 inch if someone needs some.
Frank
$25 each, add another $50 for the centers and rings...so I’d say $150 for the set of 4
14 INCH I have 8 of the stock rallye wheels don't know what to do with them ; Stopped running 14" tires years ago . trouble is hard to find 15: wheelks with sbp
I have 2 sets of the SBP ralleys, with the correct for 1970 light argent sombrero center caps. No trim rings. If a member here needs a set for a restoration, I'll let one set go for a reasonable price. We're moving south in a couple of years, so I'm starting to thin the parts bin. I know the mods will probably tag me to move this into the for sale section, but I'm living life on the edge. The wheels are the same as in my avatar.
I purchased 1 small bolt pattern 14" X 5 1/2" Rallye for $100, from a local FABO member, to use for a spare tire. He didn't want to break up his set of 4, but I only needed 1, so I paid his price. A 14" X 5 1/2" STEEL wheel would NOT clear my SSBC front disc brakes.
