Looking for 1974 Plymouth Duster wiring diagram
I have this from my 74 dart sport. Maybe it will be close.
Same for all A bodies for 70-76
Not even close to being true. Rallye dash cars and standard dash cars were pretty different, and the colors used for some circuits changed over that range. Not to mention the addition of electronic ignition, seat belt interlock devices, etc. I made a changeover diagram when I installed a rallye dash in my '74 Duster, if what you said was actually true that wouldn't have been necessary.
MyMopar has changed their layout some, you can download all of the wiring diagrams by year.
Wiring – MyMopar
You can look at the Valiant and the Dart versions and compare. Nothing is exact, but this is the one closest to my '74 Duster.
And none of those are from Chrysler Corp.
The best diagrams are going to be in the factory service manual.
For '74 you'll have to buy a copy. I don't know of any place that has them as a download.
You'll have to buy either print copy or on a CD.
I would think Bishko is your best bet, and I know they will ship overseas.
Depending on what you want to do, a '73 service manual download might get you started.
However keep in mind the stuff 72bluNblu stated is all true. Off the top of my head, I beleive '74 is the first year for the seatbelt interlock. Fortunately you can look up how they work in the Master Technicians Conference.
Also if your Duster has the optional electric defroster grid in the rear window, it would have a different power feed arrangement. Those are shown in the shop manual.
'74 is a disaster is what it is.
1 year only seat belt ignition lock out, and that stupid "delay box" or whatever that's a separate circuit board. I'm not saying they aren't out there, but I have yet to see a wiring diagram fully depict all the stuff that was in the '74 harness. It's basically a 1 year only deal.
Seatbelt interlock.... so that's why I have a "fasten your seatbelt" sign in the dash? LOL. Had no idea. I don't think the unit is there anymore. And my car has no air system whatsoever apart from the forced air on left side.
Thanks all anyway, I'll compare with the Dart one.
I think it's very weird that at this point we still struggle to find basic material such as wiring diagram and decals vector.
I've been making some and putting it available online as much as I can to help others but still couldn't find (or create from scratch) the decals for the 74.
It might be, but my recollection is the seatbelt reminder light and/or chime also existed seperately from the interlock.
Electric defrost grid is a resistance heating material on the glass. Different than the hot air blower units (also an option) and not related to air conditioning.
How rare is electric rear defrost?
The MTSC for the Seatbelt interlock can be found here
Browse MTSC by Model Year – 1974 – MyMopar
Page 1 has the explanations and note that it says the circuits are entirely different than the warning buzzer system.
Page 8 explains the overide switch
I have a 74 that had a engine fire. 74 diagrams are definitely lacking look at the 75 volarie ones they are closer.
I found what I was looking for on Google images and copied the link to my phone and went to a office Depot and had them print out a copy and a second copy enlarged... Was under $3......
I have a '74. Of course, it has that small box under the hood that only '74's have, which i currently have bypassed. I was wonder if anyone has installed a different year wiring harness in a '74. Harness swap ???
Turns out.... my car is a 73! LOL.
I can explain....
I bought the car, received it at home when I was very ill and went to ICU a couple of days later.
Back home after 10 days could barely remember my name and the memory was improving during the following month...
And for some reason I assumed it was 74 and been saying 74 for the past year and a half. LOLOLOL.
Just realised now searching for something about folding rear seat option... well...
So if anyone has a 1973!!!! wiring diagram I'll appreciate.
But at least with all this mess I managed to get an awesome literature from 67Dart273 which I'm trying to make easily accessible to all.
Regards.
Surrey as in South of London. Yes?
The quick way will be the same as I suggested above, except for 1973.
It will be in the 1973 Dodge Chassis Service Manual.
Service Manuals – MyMopar
The 1968 Master Tech Conference explains how to work the wiring diagrams used through 1973.
Browse MTSC by Model Year – 1968 – MyMopar
There are several other electric related booklets in 1973 you may find helpful.
A good complete index of almost all of the Master Technician Service Conference is here:
Master Technician Service Conference - Chrysler's Training for Mechanics
Unfortunately the Imperial Club is having web issues and many of the links are dead. So use this as a table of contents and then go to Chrysler Master Tech Service Library – Browse Model Year – MyMopar and view it there.
The 1970 Hamtramck Registry Library Page (1970 - 1974)
has most of the Technical Service Bulletins (updates/corrections)
To buy a copy in paper or on CD, try Bishko. They're reputable and will ship overseas.
