Water Pump Block Off
Ricks70Duster340
Child of the King
Sisterdale, TX
I do not want to run a heater in my 70 Duster, so want to block off the water pump tube. Is there a cap available to do that? The aftermarket intake will simply use an NPT plug.
Personally I don't trust the rubber caps for any extended periods.
You could also tap the inside of the nipples for aluminum or brass pipe plugs. (Steel can cause issues.) It will look prettier too!
Before I installed my WP, I went to the hardware store and pickup up a brass plug and a black steel Allen head plug. Ended up using the brass one in the aluminum as it’s softer than the steel..
