Princess Valiant
A.K.A. Rainy Day Auto
**** is nasty. Kinda menthol in a very odd way. Keeps the sinuses open but with that very odd taste.
When you're checking for a restricted fuel line, use an air chuck, don't blow into the line because gas will come back at you with velocity and go straight to the back of your mouth. You don't produce enough air pressure to clear the restriction so just don't do it.
Quit being lazy and in a hurry and charge up the compressor and use an air chuck.
Gas coming back at you and running down your shirt is not actually all that great because you'll smell like and taste gas all day.
