Hi Guys,
My temp gauge does not always work. Sometimes it will stop working while driving and then start working again. The other gauges in the cluster are working fine. What should I be considering first; the gauge itself that's the problem, a ground wire or the circuit board? Is there a way to test what the cause may be?
Thanks
Thanks
