Question on my oil pressure readings-happy father's day
Alright guys well I did the whole overhaul and even opted to go with a deep pan and switch out the oil pump. I cleaned up the passages on the oil pump as well and put a high pressure spring in it. Just took it for a spin and when temp is at 190-200 in gear at a light it's 25-30 now. I went with the moroso 8 quart pan as well. I think I'll see how it does and just avoid taking it out on hot days. I also switched type of oil filter as I went from a wix to a k & n gold. I'm satisfied with the results so far I'll update if any change. Thank you guys again to all your input and help
Thanks for providing an update! Too many folks get their feedback and drop off the planet. It's nice to actually hear what the resolution was.
at hot idle , u aint got a problem !
