cruiser
Hi Guys: A few years ago I replaced the starter in my slant six powered 1974 Duster. I do not believe that it was the factory original starter when I removed it. I'm curious now and am wondering if anyone can identify what year this starter was made, and what models it was used on. On the black cylindrical motor housing is the part number: 3755900 . Below this part number is the number 24. On the cast aluminum drive housing are the following: A word encircled by an oval with the word "Crotex" molded inside it, and the number 2895219. There also appears to be a date coding star with the number 3 in the center. All of the info that I've taken from the aluminum drive housing are guesses. For the most part, the numbers are nearly impossible to make out. But the stuff from the black motor cover is correct - I'm sure of that. Any ideas? Thanks - cruiser
