99CENTS
360 short block needs assembled. Come with la crank and magnum crank both std. Rods and pistons std
. Solid lifter cam and lifters new in box. Set of la heads all machine work done with 2.02. gasket set rings rod and main bearings valves.$1200.00 obo
