Look what Santa brought me for my 392 stroker!
Exciting!
Jeff
Exciting!
Jeff
@HeywodjaDouble check them port sizes on the intake... Mine were WAY small
So it's about an inch taller....a drop base filter and maybe a little thinner element and I should be fine.....I have not installed the full system yet, will be in a couple weeks, we just went to the dyno with a carb.
This is a, EFI super victor manifold and Edelbrock lists it @ Center Maximum Height 6.300 in
For comparison Edelbrock lists the performer RPM @ Center Maximum Height 5.350 in
Before porting you can see how much porting was necessary just for gasket matching.
After porting for port / gasket matching.
