MOPAROFFICIAL
Oogliboogli
Multiple things.
Multiple things.
But you can install that on the trailing side.where the zerk fitting hole was drilled..
Pinion angle may not be wrong when the suspension is loaded. But unloaded it it outta wack and put in a binding situation. Can u understand that? And comprehend it? If not get someone to help that does. Your your own worst enemy. Dam, I’m turning into RRR. KimSuper quick update:
when i turn the tire by hand, 3/4 of the rotation of the yoke is smooth, then come to a hard stop. If I really push the tire/yoke will complete the rotation. It could be a cap in the yoke? Nothing is physically binding and I don’t think the pinion angle is wrong, it’s something with the u joint. Thank you for all the help and o”pinions”!
OMFG!!! He has the diff hanging in the air. Which puts the u joints into a bind. He has been told to put it on jack stands under the diff to simulate the suspension being loaded. Kim
Found the issue, bump out from the grease fitting was hitting pinion nut. Will see if it’s possible to reverse the u joint and load the car on the 8 3/4 next time during the warm up. Live and learn. Thanks so much for the input. I didn’t see the rubbing until I loosened the u joint/driveshaft.
Still not. And likely won’t. Or it will take a few more times of telling/asking him to do it. KimYup. I agree. If he's done it yet, I haven't seen him post.
I wonder if you have enough meat there to shave off a little. With full weight on the suspension it may go away, but to gain peace of mind a shave might relieve it altogether. ya?Found the issue, bump out from the grease fitting was hitting pinion nut. Will see if it’s possible to reverse the u joint and load the car on the 8 3/4 next time during the warm up. Live and learn. Thanks so much for the input. I didn’t see the rubbing until I loosened the u joint/driveshaft.
but consider checking pinion angle when differential is on jack stands ie full weight on suspension.
