uncle tony's garage gets called out by the roadkill guys
What he does is blame everyone but himself for the failure of his project. Saw where he had a pushrod poke through a rocker, not uncommon by any means, especially when you use a worn out rocker, on a retrofit roller cam, with 340 replacement springs...valve float city....and of course its comp cams fault, cause the lifters bleed down. 100% hack
