Can anyone tell me what these fit thanks
74 360 dart sport
Montevideo Minnesota
What do these fit
What are the numbers (if any) stamped into the levers?
In the last 2 pictures, the bottom 3 rods "look" to be either 883 or 883 OD shift levers & rods. I'd have to get up under the 72 Duster to make sure, or contact Brewer's with the numbers & see what they can tell you.
On the first picture on the chair, the lever that's attached to the Mr. Gasket shifter looks like a 1/2 rod for A body, the one on the left looks like 3/4 rod along with the reverse rod all the way to the right for A body. The 2 shorter rods in the middle look like 1/2 and 3/4 B body rods. Most likely all Mr Gasket rods and levers.
Wild guess, E body the rear mount shifter position. That is not a factory shifter
