[WANTED] Wheel hub
As far as I've been able to determine, the only way you could get a new one was to get a hub and drum assembly through the dealer.....long since discontinued. I've never seen a new aftermarket one. Someone here is bound to have some used '65-72 10" front H&D assemblies they're taking off for a disc conversion. If you're lucky, you might even find a donor car in your local wrecking yard. Just make sure the races fit tight and haven't spun in the hub.
