Diego53
Active Member
Hey everyone , just got my dart a couple months ago and I found this site . Figured I should join cause I don’t know a whole lot about cars and I’m gonna be asking lots of questions . I’m pretty mechanically inclined so I know I can figure stuff out if someone explains it . Basically the thing will idle really nice I get compliments on how good it sounds when I’m starting it up but when i put her in drive she’ll go for about 500 feet and then slow way down like it’s about to die and eventually sputter out. I have replaced the carburetor, air filter, fuel pump, fuel filter, and the little sock where the fuel line goes into the carb. No dice .. now my mechanic friend is saying it’s probably the distributor that’s failing at higher rpms . Is there anything else that could cause this problem? Oh yeah and the tank is pretty new so I don’t think there’s rust or anything clogging it on that end
Thanks
Thanks
