Can anyone identify this resistor value, I tried the calculator on the interweb but couldnt seem to get an exact match. Its from a Dixco tach
Bad....Boys.....Rape.....Our.........Young........Girls.........But........Violet.......Gives.....Willingly
It might. Just get the correct wattage and the smallest tolarance (ie 1%) you can find.I think 680 is correct does the tolerance matter in this application
Which resistor? I see two
Keep it simple the chart to the left
As above white-brown-brown, white is 9, brown is 1, last brown is "multiplier" meaning "add one zero
Either way I'd like to meet her .Omg!
I learned it slightly different - violet.... goes.... willingly
