Some of you guys can't justify the GVod.
Some cannot understand 32mpgs with a 367.
Some of you just don't like me.
Ok I get that.
But do you really have to run yur mouths off at things you don't understand?
Just cuz you can't do what I do, doesn't mean it can't be done.
To repeat the story;
the day I tracked my car, I had 3.55s in the back, and the Commando A833, and as always, I was splitting gears. The first four road-gear ratios are;
10.97-8.55-6.82-5.32 The splits are .78-.80-.78
with 5.32s the math says she hits 93@6220.......
the powerband requirement of this combo, shifting at say 5800, would thus average ~1200rpm.
If you cannot see the value of 4 ratios to 93mph, which being two electric full-throttle shifts and one pull on the stick, and the engine sitting right at peak power for almost the entire Eighth; well, your insults are water off a duck's back.
There is a reason small engines have CVTs, and my GVod splitter works with my transmission almost the same way.
So, just cuz you guys can't make it happen,
BTW to pull this trick with a regular A833 and say 5.38s; the road ratios would be;
14.31-10.33-7.53-5.38, the splits are .72-.73-.71, an average of say, .72- So again, shifting at 5800, the Rs will drop to 4180, so a powerband requirement of 1620.
Of course, that 14.31 is as good as useless ..... so, you would probably gear it for three gears in the Eighth.
Ok so to get 5.32 in third, you need about 3.73s in the back; so, the road-ratios are;
9.92-7.13-5.22-3.73, but ok, I'll give you the Commando low gear, and
11.53-----7.13-----5.22-----3.73 compared to my
..10.97-8.55-6.82-5.32----------------------2.77
BTW, my third gear is 4.97, for 93=5765; lemme put that in the line-up for you, with the rest of 'em;
..10.97-8.55-6.82-5.32/4.97-3.88/3.55-2.77
Hyup, 8 stinking usable ratios, that I use in several different ways.
But if you run a 4.10 like some guys do, then
12.67(Commando)-7.87-5.74-4.10; with 26.5s that makes for 93=4840 in Fourth/6770 in Third.
So there ya go, try to find the perfect rear end/tire/and cam combo, to use the regular A833, in the Eighth; good luck with that.
I hit the numbers with a smaller cam, because of the agreeable ratios on both ends, plus the 180psi CCP, plus; I only have to tug on the shifter but one time.
But you know,
I'm just a streeter,
so what do I know ........
Go ahead insult me some more;
it speaks directly to your character .....
B3,
Numbers don't add up.....
You say the cam is very sedate, idles smoother than the same cam in a smaller engine.
The implication from that is that it is not the same cam that is being compared.
I doubt the cam is retarded if it idles smoother because retarding a cam usually worsens idle quality.
B3,
he does have full exhaust on the car, so it tends to influence my opinion somewhat.
But the idle seems way less choppy than my 360 did with same cam and similar( probably) compression.
Remember, this cam is on a 106 Lsa, so by nature its going to have a choppier idle, especially installed per Howards 102 recommendation.
Around here? Are you kiddin? That would make too much dang sense.I’m surprised the compression test hasn’t been tried yet.
Takes 5 mins and would shed some light on the situation.
If it cranks like 130-140...... you have your answer.
If it cranks 180-200......it’s unlikely the cam install is way off.
150-170...... eh...... maybe/maybe not in wrong.
On another note, 260@.050 on a 106 and closed exhaust isn’t going to be super happy.
So the 260 / 265 is that advertised duration or at 50 because if that's advertised duration that's pretty mild cam and compression should not be an issue I was assuming it was at 50° and in that case flat tops and standard Edelbrock combustion Chambers are too big in my opinion.
its 260/264 at 50…. Its big
296/299 advertized
compression test is a good idea. Its not my car, i can only suggest tohim what to do.
He is hard headed…runs in the family..lol
LOL I can respect that. Yeah that's a whole lot of top end for a 340 in my opinion that is (dome piston) territory or extensive milling to the heads and even with that I wouldn't expect that motor to start coming on till about 4,000 RPMs to 8,000 RPMs with a sweet spot between 55 and 7500 or soits 260/264 at 50…. Its big
296/299 advertized
With a flat tire....and got 49.3615 MPG on the way home. Uphill in the snow. With 165 MPH head winds. On 79 octane with no spark knock and 95.6 degrees total locked out timing. All while running 159 degrees and turnin 1200 RPM @ 90MPH.
With a flat tire.
an hour to pull that cam and be sure its what it is. Id rather pull a cam that till the garden!
Honestly, he asked a question or two and then went on to brag. Ho-Hummm….Nuthin, as usual......and I didn't even read it. LOL
Did I ever tell you guys how much I like simple azz timing chains and doing my own work. Easier to do it yourself and know it’s right over trusting someone else to maybe doing it right.
No, the choppiness will be a little less as the cam is advanced and a little more as it's retarded.....although I'm not sure you could actually hear a 6 degree difference one way or the other.....I could be wrong.
i think the choppiness will be more noticeable advanced, not retarded.
Retarded will tend to smooth it out
