B Bodies Site
It's mind-boggling....
Lay it on us. What you small-car guys got issue with?
Ok i need this HEMI out of my 69 charger and Cram it into this small a body then take this 6pak out of this one and put into this one
Whew, almost forgot my login over here.
I usually scan for small block parts.
It's a curse. I've tried buying 4 Dusters in a row and none of them worked out.
How many A-bodies does it take to screw in a light bulb?
Can’t do that till it’s up n’ running. Lol!!
True that. I have 5 sites open right now as well as posting on a half dozen elsewhere in the net. Sometimes hard to keep all the conversations straight. Regardless ow whether the site is open or not, if you can't remember your password you can use the "forgot my password" feature.
