Just finished removing all paint (and small amount of body filler) from my 72 dart. Used 80 grit paper on a da sander. Should i sand with 120,or 220 paper before i put on epoxy primer?
Epoxy right over the 80 gritJust finished removing all paint (and small amount of body filler) from my 72 dart. Used 80 grit paper on a da sander. Should i sand with 120,or 220 paper before i put on epoxy primer?
