its a 73 duster,it's says right up top'67-76 will fit the car as a repair panel. The differences are: moldings and emblems obviously, but, also side markers changed through the years. '67-no marker, '68 round side light, '69 rectangle reflector, '70-1 flush mount light, 72-up rectangular surface mount side light. Some had turn indicators on top the fender too. There were also various grille/latch support/mounting tabs that need to either be transferred or removed.
THANKS, I know enough that the 67-69 won't fitYup, saw that. I just thought you might want the interchange info if you can't find the exact year fender.
A friend is collecting parts for a resto, he wants a rust free drivers fender
EDMONTON ALBERTA
