Steering Column?
coalman
Texas
What holds the cover behind the housing for the directionals to the steering column? Masking tape with arrow? Thanks
Mymopar.com, download your cars factory service manual.
Its all in there.
I suspect you pull the steering wheel, then some screws for the turn signal switch, then most likely some screws or a set screw or the like.
If you are asking about removing it completely, i suspect you will have to pull the column.
Its all in the FSM
Thanks, I have the shop manual, found it in the electrical section, not any information on the cover. I will just have to pull the steering wheel and take a look..
