AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,861
- Reaction score
- 12,209
I agreeU may also have a truck mount bolted to ur crossmember and I believe they are a little taller than a car mount Kim
As an example;
My 68 Barracuda is wearing a 73 up spool mount crossmember. On it, is a long-tail A833 which has the same trans mounting point as any pass-car 727. My spool mount is shorter from the trans mounting-surface to the bolt-tunnel, than yours is.
