Proform Dizzy kit
plymouth1937
sweden
Hi anybody having any op about proform dizzy kits bout a new one here in Sweden and it has workt fine until tonight parkt thé car coming from a shopping trip and put the items in the house and went out to move the truck stone dead no spark is these ecu just crap or what i turned it of and now no spark
Could be 1 of three things.
Ballist resistor. (Just happened to me)
Distributor pickup
Coil
Distributor pickup
Coil
When i orderd the Dizzy i asked if my msd blaster coil whold work and he sad yes but i had to skip the ballast onley got 9v out of the lead to coil
I have found very very little info on those. I "assume" and this may be wrong--that they use a module similar to a GM HEI. The "Skip White" "ready to run" which is a similar deal uses a module that is readily available and used on Australian Holden vehicles. Maybe ProForm is the same.
If you can get it apart, and find that the trigger assembly is still good, there is no reason you can not adapt a different electronics box, Holden, GM HEI, or MSD
Many of us on here us a Mopar breakerless dist. to trigger a GM HEI module
Yes but this is not a hei dizzy this one is a copy of Mp Dizzy il hook up the 6al and try
OK so it's just a trigger and no electronics. Well I don't know. "The standard" tests---inspect it visually for debri in the trigger/ pickup, hook a meter to the pickup output and spin the dist. With the meter on low AC volts it should generate somewhere around 1volt AC Check pickup coil for resistance. It might be open. As I said I've found little info on these
oh its a miracle the car starded today gona pull the dizzy and test it i bet its the ecu it was raining yesturday so i ges thats the problem the msd is going back in
Very little can fail with the pick up:
- if the vac adv is used, the wires can break after maaaaaaaaaany miles
- worn shaft or top bushing can close up the air gap to zero. No spark if contact is made between reluctor & p/up node.
I Agree the first thing i chekt was the pick up gap its all new stuff so no ware
The guy that sets up my dizzys won’t touch Proforms.
Nothing wrong whid the Dizzy it self nice castings and so on but far from my favorit iv mod a lot of diferent brands over the 35 years iv been activ as a drag racer and by far the best Dizzys iv workt on is the older Mp e distributors a lot of the newer ones are made in china even knowed brands like msd no boeno
