71 hemi orange swinger rescue.
Show us a pretty painted motor picture.
You mean
like this?
While installing mini starter in the 67 Coronet in order to move it so I could move the swingers engine into position for install we ran into a problem. It has a 360 magnum as well. There is a bump on the magnum that is not on the LA. Shouldnt matter as I used a magnum starter? Nope a little grinding on both magnums and we are back on track.
Transmission, converter, starter, covers, exhaust, oil and filter done. Have a bolt to extract, install intake, fuel pump, water pump, power stearing pump, carb, new radiator, dizzy and who knows what else.
Well bolt problems on the 4bbl intake necesitated a switch to the 2bbl intake.
She fired up easier than I thought she would. Thanks go out to @dartfreak75 and @318willrun for the push in the right direction.
Great work bud! Glad its running. You can get that broken bolt out! Take a nut and thread it on and weld it on the top. Heat around the hole and it will come out. I like to heat around the bold then spray some penatrate then reheat again then try to ease it out.
Cant get penetration on the grade 8 bolt, only on the nut. But will get it eventually.
Those dang things can be stubborn. I broke one of the exhaust studs off in my head I tried everything ended up having to drill it and retap it. I managed to get it centered enough that I didn't have to go up a size in thread just drilled out the the old bolt and cleaned out the threads
I need to get a better drill bit and drill it out on the milling machine.
Great job. I find these threads so satisfying to read. I dragged home a barracuda that was sitting in a back alley for 3 years and got it back on the road.
Keep us posted.
