olddman
Need some help from the experts. Have a 1965 Dart Gt with a 8 3/4 rear end in it. The drivers side grease seal was leaking so a friend on mine and I have been working on replacing the seals. Pulled the axles and somehow the axle on the passenger side had been rubbing on the face of the outer seal. It was not leaking, but the metal part of seal was close to being worn through. While the axles were out I decided to do away with the green bearings and install the roller bearings.
Got seals installed, bearings replace and slid axles in. Tried to adjust preload on passenger side but the lock ring would not turn. Ring was binding on rise where axle bearing is pressed on. Removed axle and had area turned down thirty thousandths. Installed axle and there is no slack to adjust preload. Have I done something wrong? Scratching my head as what to do!
Am I correct in that part numbers were not stamped on factory axles? These axles have numbers stamped on them. Have ordered new lock ring to try.
Do I need to get new axles or am I doing something wrong installing these axles?
