Flywheel question (I'm new)
MR2ninja
Active Member
New Mexico
I've got a 1972 Plymouth scamp with a dodge 360 1978 date code on the block. I have a leaky 904 and want to do the $$$million dollar$$$ 4 speed A833 swap. What flywheel for my externally balanced 360 from 1978 do I need? What clutch do you guys recommend?
Check out Portland OR Craigslist auto patrs "mopar" just saw most everything you need pedals, bellhousing, trans, since you are in the west maybe you can talk them into shipping and then buy small components from Brewers such as fork and pivot, ball studs etc. that is how I did mine and a whole lot cheaper, I found a lot of stuff that I was able to drive and get and maybe you could check and find it closer also
